TractorLinks.com
Re: 1965 Sears 12 hp graden tractor
joe csuti
01-03-2013 02:57:25
As shadetree said check flywheel cover for an id tag or check to see if HH120,type# and possibly sn stamped in cover,or if cover has a tag with a sears mod# on it starting with 143 write down number & goto link below,see if eng still listed at sears website.If eng still listed look at assembly drawings/parts list for carb pn & pn for a rebuild kit(if listed)most pn at sears site are tecumseh(if eng a tecumseh).
If you can't find listing for eng at sears website,take sears mod# from tag to one/more local mower shops,most shops have a sears/tecumseh cross ref that they can lookup tecumseh eng from that number & order rebuild kit or complete oem/after market carb(if needed).
Once you have pn of carb you can also check on ebay for a new/used oem/after market carb or do a goggle search for tecumseh and carb pn,you can also locate a rebuild kit the same way if you have pn for kit.
MNGB
01-03-2013 10:54:44
 Re: 1965 Sears 12 hp graden tractor in reply to joe csuti, 01-03-2013 02:57:25
If the engine is original it will be a cast iron Tecumseh 12 hp (HH120 or a Sears number) they use a Walbro LME carb not that easy to find but they come up on E bay regularly, if you have the carb it can be rebuilt, kits are available and if the carb body and throttle shaft are badly worn the is a fellow, Mark Hare that makes throttle shafts and bushing or you can send your carb to him and he will rebuild it and it will come back like new, I tried getting on his site but it must be down today, Goggle carb rescue.
GB in MN
This post was edited by MNGB at 10:57:17 01/03/13.
