Hahn-Eclipse Snow Giant CHD-584 Parts
chd584
New User
I'm looking for a parts list for my CHD-584 Snow Giant.
Specifically, the correct spark plug/gap and other servicable parts (drive belt, oil, etc.)
Thanks.
I'm sure I can find the info you need. Check out my website for some additional Hahn info. I'm working on organizing all the manuals etc I have. What engine and engine numbers are on your machine?
Zac
(quoted from post at 16:41:15 12/28/12) I'm sure I can find the info you need. Check out my website for some additional Hahn info. I'm working on organizing all the manuals etc I have. What engine and engine numbers are on your machine?
Thanks for the quick reply, Zac, and nice looking site!
The engine is a Tecumseh H70-130025 (serial # 0184 17409)
The snowblower is a 7523 Series, Model CHD-584- (last part obstructed by rivet) (serial # 0632989)
If you have a manual for this snowblower, I'd very much like to get a copy.
Ok,
I will look when I get home next week and get back to you. I have a very similar model (CH-588-7) with the same engine.
Zac
I was unable to find the Snow Giant manual in my stock. I'm checking to see if my buddy has one (I think he does). I'll let you know.
Zac
Zac, you mentioned earlier you own a similar snowblower with the same engine. Can you check to see what spark plug and belt you are using? Thanks.
I found a service manual for the H70 on the Tecumseh website, http://www.tecumsehpower.com/CustomerService/BSI.pdf, which identifies the recommended spark plug as a Tecumseh # 33636 and cross-references with a Champion RJ17LM or Autolite 245 (superceded by 456).
This manual was published in 2009, so I'd still like to get a vintage manual to see what the recommended spark plug was in 1971. Some third-party vendors (e.g., http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-H70-130025-PARTS-LIST.pdf), list Champion RJ8C as a suitable replacement.
Also, the parts manual I got on the Yahoo Groups site identifies the belt as Hahn # 308452, which cross-references with a Dayco 3VX335. My used snowblower came with a Dayco 15335 belt, which is similar but not a direct replacement. The 15335 belt is stocked by my local auto stores, but the 3VX335 is a special order which might be why it was installed by the previous owner.
my buddy will look for the owners manual tomorrow. I am running a J8C Champion in mine.
(quoted from post at 21:45:35 01/08/13) Send me your email address and I'll send you a parts manual for your CHD 584-7- series 7523 year 1971
The belt is a 3/8 x 33 but there are no numbers on it. The previous owner wrote that on the belt guard and by the looks of the belt on it I'd say its right.
(quoted from post at 02:45:35 01/09/13) Send me your email address and I'll send you a parts manual for your CHD 584-7- series 7523 year 1971
Thanks, Gary.
I believe I have the correct parts manual -- Form # 343436
If not, let me know and I'll send you my email address.
(quoted from post at 03:26:49 01/09/13) my buddy will look for the owners manual tomorrow. I am running a J8C Champion in mine.
Thanks for the spark plug and belt info, Zac.
I look forward to seeing the owners manual.
Hi there,
my buddy sent me the parts book but you already have that. We don't have an owners manual for your exact model but he is going to scan the one he has and send it to me. It will be close but not exact. Yours is rare because it is a Snow Giant "Super" model, not sure what makes it a super, but if I find out I'll let you know.
(quoted from post at 02:48:16 01/10/13)
Much thanks, Zac.
Also, FYI, I came across an H70 engine manual circa 1980 which lists Champion J8 or J17LM as the recommended spark plugs (non-resistor):
http://www.brentchalmers.com/Manuals/SuperTomahawk5-8-2GC_OwnersManual_TecumsehEngine.pdf
I started another thread about this manual, and someone said they might have one circa 1970. I'll let you know if it pans out.
I have the scans now of the owners manual. It covers CH-584-5, PH-584-6 and PH-584-7 models. I can email if you want.
(quoted from post at 11:45:08 01/11/13) I have the scans now of the owners manual. It covers CH-584-5, PH-584-6 and PH-584-7 models. I can email if you want.
Great! I have emailed you at your gmail address since private messaging seems to be disabled for this forum.
