Yesterday's Tractor Co.
Shop Now View Cart
Re: Gravely Tractor walk behind
12-30-2012 08:35:40
You mentioned you rebuilt the carb. I rebuilt the carb on my JD 425 this year and I had the same problem. Check your throttle plate, if it is open more than just a little, this could be the cause. I accidentally put a stop screw in backwards that kept the plate open a little more than it should have, causing the engine to race. Good luck, you'll find it.
Farmall Bob
12-31-2012 05:57:27
 Re: Gravely Tractor walk behind in reply to Dan50, 12-30-2012 08:35:40
Hi Dan,
You were right! I found the problem yesterday morning. I found excessive endplay in the shaft to the Baffel Plate and placed a washer on the shaft to take up the slack. Wrong move as it made the Baffel Plate rub and would not close all the way.
