TractorLinks.com
Re: 782 no electric
joe csuti
12-27-2012 07:24:30
Check sn of tractor on id plate,if 720,000/above there are 2 fuseholders/fuses behind dash,one fuse is main power to ign sw and is installed between battery pos(+) and pos(+) terminal on ammeter,if this fuse blown nothing on tractor will work(starter,lights)2nd fuse is for headlights/tail lights,if fuse between battery & ign sw not blown then there is an open circuit between battery terminal on starter sol & ign sw,possible causes:
Battery cable loose on starter sol terminal.
Wire to ign sw loose/broken on sol battery terminal
Ammeter bad or connections on same loose/broken
Ign sw bad.
Loose or bad neg(-)battery connection to eng block/chassis due to rust/dirt.
Ken_484 International
12-29-2012 14:50:31
 Re: 782 no electric in reply to joe csuti, 12-27-2012 07:24:30
You may have pinned down the issue. I have not had much time to work on the tractor, but I did remove the fuses. They looked fine, so I put them back. I tried the ignition and had power but just for a moment.
Old Roy
01-01-2013 20:17:18
 Re: 782 no electric in reply to Ken_484 International, 12-29-2012 14:50:31
try swapping fuses one is for the PTO other ignition.. seldom both go bad at the same time.
Old Roy
01-01-2013 20:16:50
