TractorLinks.com
JD 316 motor needed
Jason Jonckheere
12-25-2012 19:11:44
I have a chasis for a john deere 316 with a blown motor. I would like to find a reasonably priced motor to put back in it. I am from michigan. Thanks Jason
Traditional Farmer
12-28-2012 06:02:23
 Re: JD 316 motor needed in reply to Jason Jonckheere, 12-25-2012 19:11:44
You should be able to find a good used 16HP Kohler pretty cheap as there are many tractors and equipment that used them.JD does have sort of an odd oil pan so you need to watch that,think Cub Cadet is the same.
steve_in_mo
12-26-2012 16:56:25
Overhaul should run about $500 if your block and crank can be machined to a standard oversize/undersize.
El Toro
12-26-2012 11:24:08
Smallenginewarehouse has a 341 short block for
$950.00. Hal
PS: You would use the old pan and head off the old engine block. Gaskets may come with the short block.
El Toro
12-26-2012 04:02:39
I bought a Kohler short block for a JD140 back in 1980. Back then they were about $300.00. Hal
d beatty
12-25-2012 23:49:30
You could give Small Engine Warehouse a call. They can get you almost anything you need.
JT Britt
12-25-2012 21:39:42
Depends on which engine you have.Early 316 single cylinder Kohler.Late 316 twin cylinder Onan.Great big ole difference in money.To rebuild or replace.
ken combs
12-25-2012 20:42:04
I have one. Unfortunately it is in Oklahoma a is heavy. So, shipping would be expensive.
If you can find a reasonable way to move it, let me know.
steve_in_mo
12-25-2012 19:25:54
That 16 hp K341 is a highly desirable motor. Unless the block is cracked or ventilated by a departing rod, it is usually better and cheaper to overhaul it than replace it.
If you want to repower the tractor the most popular setup is the Briggs Vanguard, avalailable from several online sources. They will sell a kit to make the swap almost plug-and-play.
Jason Jonckheere
12-26-2012 06:14:43
 Re: JD 316 motor needed in reply to steve_in_mo, 12-25-2012 19:25:54
Thanks for the suggestions! It is a kohler single cylinder.
