Yesterday's Tractor Co.
Shop Now View Cart
Re: Repower Bolens 1250 with Kohler engine?
12-12-2012 21:55:58
I put a 16 hp twin Onan out of a sears suburban into a Bolens which had a very tired Kohler in it. The Onan was shorter and the crank bigger but I was able to turn an adapter to receive the larger crank into the front U joint of the driveshaft to the pump. It had a loader on it which ran off a pulley attached to the flywheel which I had to adapt as well. Once it was running it was a bear. Ended up modifying the steering arms which were to short and cheap cast iron which cracked. I made new out of sculpted steel and lots of wire. It had hydraulic power assist steering which sort of worked. John
