Sears Suburban Tank
S/C BOB
I fixed a leak on my gas tank some time back. Well it started leaking again so I put pressure on tank this time and found 3 leaks so after about an hour no leaks. So after work today I guess I ll go to the shop and put it back on. I also replaced the intake gaskets. It s been almost 2 years since I ve driven the ole girl. I also want to replace the seat. The mower is a SST/16 with the Onan engine.
This tank is in 3 sections so it was just resoldering the joints. PS I sure wish I had 3 point hitch and turning plow for it.
I have three point hitches for the Surburbans:
Manual lift and electric lift, and I have plows, disc, rear grader blades, and front dozer blades
All priced to sell.
Hi Stanley where are you located could you e mail me gbsb2002atyahoo.com just remove and add the @ as needed
GB in MN
