Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 516 H
Old Roy
12-07-2012 18:34:41
Rained all day here and both my wheel horses are outside.. I have a one car garage dedicated to my Cub Den that has a broken cub, a broken little Craftsman , and a larger Craftsman ,( for now my main mower)
The wheel horse came with a parts tractor , although it is a little different looking, older model. (transmission will not let it be pushed backwards) but is does have those thumb levers you are talking about,(Can almost see the tip of it on the right side).... just possibly the transmission pulley will fit the 516 also. question from there is mounting the blade ? it has a bar on the back to click into those levers.
further up there is a vertical piece of metal with a hole in it. wondering how that is attached to the lift arm ? maybe a chain??? I had an older one long time ago ..seems to me it had a chain.
joe csuti
12-08-2012 04:18:49
 Re: 516 H in reply to Old Roy, 12-07-2012 18:34:41
Goto link below,click on toro logo,enter 06-48BC01 in mod search on left side of pg,this is a complete assembly drawing/parts list for blade.
In pic you posted the orig handle is laying against blade,Thin rod from squeeze grip on handle went to a bellcrank mounted on angle bracket by handle mounting/pivot bolt,from bellcrank another thin rod ran to latch plunger to hold blade in position after changeing angle,also many of the pre C/early series C tractors used a chain rather than a bar to connect blade to lift handle arm(I have both styles),the chain/bar usually connected to center/intermost hole on rock shaft arm closet to lift handle
The usual method to install blade on tractor is remove pivot bolt for handle,remove or lay handle on ground,drive tractor over blade frame,slip cross shaft on A frame into quick attach on axle & lock,connect arm/chain to lift handle arm,reinstall arm for angle adj on blade.
Old Roy
12-08-2012 10:55:04
 Re: 516 H in reply to joe csuti, 12-08-2012 04:18:49
Thanks Joe, I see the missing parts here..
Dummy me, I have used this site many times for my Cub Cadet Never thought to look here ...
Copyright © 1997-2015 Yesterday's Tractor Co.
