70D
Ok this is the second time I have rebuild the carburetor on My John Deere 110 with a kohler 181 engine now it run about three minutes start to back fire then dies any ideals
back fire is a lean broblem. Had a 214 do that to me over the summer. Found a piece of rubber from the fuel line on the back side of the fuel seat. ended up putting a screen in the fuel elbow at the carb. Seems simple but an easy miss
Tim
That is what I taught but never hurts to check if any one has had the same problem plus I had ran it out of gas right after rebuilding the carb so mite have got a little dirt out of bottom of tank
Heres a tip on kohler engines. Sometimes with a kohler bad ignition points will mock carb problems. Make sure your points and condensor are good! Dave
