Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: Case 224 winter use
[Show Entire Topic]  [Return to Forum]
Tom Arnold
11-27-2012 04:47:33
174.95.24.192
When you think about the electrical system of your Case, the
only items that draw current that are not attached to the engine
block are the two headlights.
The item that draws the heaviest current is the starter and that's
why it is important to ground the battery to the block. That said,
I agree that having a modest grounding cable between the block
and the frame is a good idea to ensure that headlights and the
voltage regulator are properly grounded.
You said that you replaced "both" cables and that implies "two",
not three. You have a cable to ground the battery, a cable to
supply power to the solenoid and a cable to connect the solenoid
to the starter.
Keep in mind that Kohler's are fitted with ACR or automatic
compression release. This feature opens the exhaust valve
slightly to allow the starter to spin the engine over easily and
when it reaches a certain RPM, the valve closes. If you do not
have your valve lash set properly, then the starter could be
fighting compression and struggling to get the engine spinning.
You can also do a test to see if there are any problems with your
electrical system.
Remove the spark plug wire so that the engine will not start.
Then spin the engine over using the key switch to get a sense as
to how fast the engine spins.
Then use a set of decent booster cables to connect the negative
side of the battery in your car/truck to the engine block and then
connect the positive side of that battery to the big lug on the
starter solenoid that hosts the wire going to the starter. The
starter motor will instantly begin to spin. The issue is....does it
spin faster than it did before?
If it does spin faster, then you still have a problem with the
electrical system in the tractor. Recent battery or not, perform
the tests I suggested. The hydrometer test will show if one cell
is weak and that's all it takes to make the engine spin slow.
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
