I have a TRA10D motor that I"ve been using on my generator, that now after a few hours of running, won"t start.
While it was running, the condensor wire pulled out, so I replaced it with another condensor that I had, started back up and ran for another hour until I shut it down.
I"ve had the carb redone, and I"m getting spark. It does seem like it wants to start but doesn"t. Using the starter it will "pop" once in awhile and I can feel the head getting warm like it"s firing but not stong enough to do it under its own power.
Would the "wrong" condensor cause this and if so, what is the correct one to use? Any other thoughts? Thanks
