Yesterday's Tractor Co.
Shop Now View Cart
Re: Wheel Horse 12 Question Update
joe csuti
11-26-2012 03:51:55
Looks like you found it,the probable cause of not being able to turn valve is probably due to seal that shaft goes thru & 2-O rings on valve body are probably age hardned/taken a set & valve body possibly gummed up from sitting so long,this problem may cure itself once you use tractor for a while & get transaxle hot.
To see pic of valve goto link below,click on toro logo,select lawn/garden tractors from list,enter 1-0435 in mod# search on left side of pg,this is a 14hp tractor,but trans is the same,look at last drawing in assembly drawings/parts list,piston-piston type(plate 4.5)look at item# 108 in drawing(bypass valve)in one of the other hydro trans drawings/parts list the older style tow/push valve is also shown on top of manifold.
