TractorLinks.com
Re: JD 420
chevy65
11-25-2012 16:17:59
Ur problem is simple Depending on age of tractor the hydro linkages vary Problem is u have excessive play in the linkage Most likly spot is the arm that hooks to the transmission The arm is attached to the trans by a roll pin it is probably broken or the arm is sloppy on the shaft other sloppy areas in linkage will cause problems too
BSpauld
11-26-2012 06:59:24
 Re: JD 420 in reply to chevy65, 11-25-2012 16:17:59
Thank you for the advice. I will check that out.
chevy65
11-26-2012 15:53:30
 Re: JD 420 in reply to BSpauld, 11-26-2012 06:59:24
let me know what u find Good luck
