Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Wheel Horse 12 Automatic Question
[Return to Forum]
Mike in MI
11-21-2012 18:24:04
74.36.237.161
I pick up a 1973 Wheel Horse 12 that has hydro transmission the other day and I"m some what a newbee on these models. Question I have is I can"t seem to find the free wheel valve so I can move it when engine is shut off. Mower has been stored in back of a van truck for better than 30 years. (had to load it the hard way)
I looked all over on the transmission and probably past over a few time and didn"t know it?
Thanks for your help. Have a Happy Thanksgiving. Mike
[Reply]   [No Email]
Mike in MI
11-22-2012 13:43:47
74.36.237.161
Re: Wheel Horse 12 Automatic Question in reply to Mike in MI, 11-21-2012 18:24:04
Thanks you guys for answers & help on this. I will go down to the work tomorrow and take a look at the transmission. 6jack, URL link I pulled up a picture of the trans. I think the transmission in this mower a Sunstrand-Hydro? Model # 5.1010 8
Thanks Again! Mike
  [Reply]  [No Email]
joe csuti
11-22-2012 03:35:20
151.198.123.168
Depending on when in 73 tractor built,tow/push valve could be in 2 different locations on hydro pump due to fact sundstrand changed over to a piston pump design & a new manifold on same in mid 73,hydro pump may be older style used to mid 73 or newer style pump.
With fender/seat raised & looking at pump from pulley side,look at manifold mounted on rear of pump,look at left top corner of manifold,if pump pre 73 design you'll see a stub shaft in left corner with a roll pin thru it to form a T handle(roll pin may be missing)turning this shaft 1/2 turn will put hydro into freewheel.
If no stub shaft in top of manifold then pump newer piston style(after mid 73)got to opposite side of tractor to see rear side of pump/manifold(left side of tractor)look at left forward faceing side of manifold,according to service manual at very bottom of forward faceing side there should be a stub shaft in manifold(may/may not have roll pin in shaft)this is tow/freewheel valve.As has been said there should be a decal on frame/trans with an arrow in it pointing to valve,but it may have come off.
Goto website below with mod/sn of tractor off id tag,see if service manual for transaxle avail as a free download,also check if operators manual a free download.
CAUTION-IF you start fooling with trans & have to add fluid on pre mid-73 pumps trans fluid is ATF dexronII(red)if pump mid 73/later fluid is 10-30 or 10-40 SAE motor oil,do not mix the oils.
https://lookup3.toro.com/request/request.cfm
  [Reply]  [No Email]
6jack
11-22-2012 03:20:36
71.173.166.232
manual
  [Reply]  [No Email]
wisbaker
11-21-2012 20:39:27
207.118.181.192
My Wheel Horse 525-H doesn't have one, you can push it around the shop SLOWLY. Sticker on it says hand push only, towing may result in damage.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
