TractorLinks.com
Re: JD 317 Repower
steve_in_mo
11-20-2012 08:37:49
The most popular repower for older hydrostat garden tractors is the Briggs Vanguard, followed by the Honda engines.
If you are stuck on a diesel, you might look for ideas at a 332, which is a little Yanmar diesel in the same footprint as the 317. I know a couple guys have put Kubota engines from refrigeration units in garden tractors but I don't have a link to give you.
smokeshow
11-21-2012 07:26:31
 Re: JD 317 Repower in reply to steve_in_mo, 11-20-2012 08:37:49
Thanks for the responses guys. Before I pull the engine. Can the pressure feed cranks be purchased? If so maybe I can swap cranks out and rebuild the original engine. Any thoughts?
ken combs
11-21-2012 16:38:46
 Re: JD 317 Repower in reply to smokeshow, 11-21-2012 07:26:31
There are other differences in the blocks. The Series One cannot be made into a Series two. Inadequate oil pump, oil galleries, pressure relief valve etc.
go to the Kohler web site, download the manuals and compare oiling systems.
steve_in_mo
11-21-2012 09:41:09
A good machinist could drill the crank you have but you still wouldn't have much oil flow or pressure. A Magnum 18 is very similar to a Phase II KT-17 with electronic ignition. That's an easy changeover.
