Yesterday's Tractor Co.
Shop Now View Cart
Re: 318 deere won't start
El Toro
11-11-2012 04:42:57
If you have points make sure they're open then with your ignition switch in the on position use a volt meter or test lite to see if your have battery voltage on both small terminals. Also rub the points with some 320 wet or dry until they're shiny. Also make sure your points are set correctly & opening and closing and your rubbing block on your points isn't worn off. Hal
