917.256.582
Kohler engine CV15.5S
Spec 41508
Serial 2525519324
I am guessing early 90s. It has a fuel pump. The hood is large like the silver LT1000.
I opened up the carb and was suprised to see a teflon brass needle tip and a rubber seat in the same carb.
It is not in too bad of shape if it is 20 years old.
I have changed the steering shaft support bushing on several Craftsman mowers. This is the most complicated. I could not get the assembly out of the frame even tho I had the dash,ect loose unless I removed the engine. I decided to replace the bushing with the assembly in the frame.
I am trying to figure out the age for a customer.
Spec 41508
Serial 2525519324
