Allis charmers 410
G1355
Had a blade that I made but I wore it out for my Allis 410. I mounted it were the deck goes like the b series Allis. I was hoping some one could post a picture of there blade of a 300 or 400 series Allis on here so I can see how they mount. I know it's suppose to mount to the frame but want a picture before I start building one. Thanks
You might find something to help on this site. Simple Tractors has info on several manufacturers machines and implements.
http://www.simpletractors.com/models/300_series/more_attachments.htm
I'm looking to do the same thing, but AC didn't build a "belly" blade for these (that I have found). I'm gonna start by building and attaching like the deck. let me know if you find anything out.
Do you mean like a road grader, blade that mounts between the wheels like the deck. If that's what your talking about the did make those, I have the original owners manual and they call it a grader blade, have seen a couple pictures of them think there pretty rare though.
I have not seen them. I even looked on the AC site and found nothing. It would be nice to find one, or even see one.
GRADER BLADE — Center-mounted grader blade angles either right or left to shape ground beautifully and exactly. Coupled with the electric lift, the grader blade gives you pin-point control. The 42” blade is reversible for extra wear.
Couldn't find the picture of the 400 series will post if I find it, that's the info on top out of my owner, operators manual hope that helps. Should be the same as the b series though I think.
It's not shown as a specific 400 series accesory but just get a blade for any simp/AC large frame and hang it on.You can use the push blade lift,but not the blade,it's too tall and not heavy enough!
