Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Briggs coil
[Return to Forum]
S/C Bob
10-22-2012 16:44:32
71.80.92.90
I think I need a coil. I replaced the condensor on my Briggs horizontal engine which I think is a 10 hp. but I m not sure. There is no numbers on it anywhere. The numbers for the condensor that fit it are 291369. The engine quits running after it warms up. The condensor didn t help. I know that s not much to go on but can someone help,and how interchangeable are the coils as I have another engine that is blown up I could use that one if the coil will fit.
[Reply]   [No Email]
Old Roy
10-28-2012 23:46:12
71.206.209.119
 Re: Briggs coil in reply to S/C Bob, 10-22-2012 16:44:32
If you are talking the magneto may be bad, and have an electric start on that engine you could eliminate the "Kill wire" to the points,using it for the - side of the coil and put on a regular (Automobile style)coil, and run a hot wire to the + saves from pulling flywheel.
[Reply]  [No Email]
joe csuti
10-23-2012 13:18:18
151.198.127.64
Try cleaning off flywheel cover & look on all sides of same closely in sunlight or with a bright light,on some mod briggs eng the mod,type & serial numbers are stamped into flywheel cover,although sometimes briggs stamping leaves a little to be desired.As far as swaping coils from another eng this is something you'll have to try or IF you have mod#'s of both eng goto partstree,or outdoordistributors online & lookup coil pn for each in eng parts listings to see if the're the same pn,many times the coil will look the same but depending on age/mod# of eng coil you are trying to swap may not work due to fact some older mod eng had reverse polarity on flywheel magnets.
[Reply]  [No Email]
El Toro
10-22-2012 19:17:14
108.3.143.30
Have you checked for fire to your sparkplug after it quits running? If it has fire I think
you have a fuel problem. If you don't have any fire to your plug when quits and you have battery start I would install an auto type coil if you have points. Run a hot wire thru a switch and to the coil + terminal and a wire to your points from the neg terminal. Disconnect the wire from the old armature to the points. Hal
[Reply]  [No Email]
Jerry Coulter
10-23-2012 11:27:04
50.40.219.115
 Re: Briggs coil in reply to El Toro, 10-22-2012 19:17:14
I had the same problem. That is exactly what I did to the B&S 19D on my Sears Suburban 725. After I replaced the spark plug, coil, condenser and points, I concluded the flywheel magnetism is weak.
[Reply]  [No Email]
El Toro
10-23-2012 11:52:27
108.3.143.30
 Re: Briggs coil in reply to Jerry Coulter, 10-23-2012 11:27:04
That poor magnetism happens a lot on these old engines. It also happens in magnetos on farm tractors. A lot are unsheltered then expect the engine to start. Hal
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
