Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Wheel Horse Tractor/Snow Thrower
joe csuti
10-18-2012 18:24:47
If you haven't done so already,check that eng/trans belt not broken or belt off trans pulley,check that woodruff key that connects trans pully to input shaft not sheared missing,if you can roll tractor by pushing/pulling with eng off,check around on transaxle,there's probably a manual tow valve on same that my be in the freewheel position allowing you to roll tractor when eng not running,you shouldn't be able to roll tractor if tow valve not in freewheel position,also check trans fluid level,may be low or filter plugged(if trans has).
If trans has ext disk type parking brake,check that brake caliper not frozen in applied position due to rust/dirt.Check woodruff keys on both rear axles that connect wheel hub to axle that they aren't missing/sheared,if either key sheared/missing tractor won't move,both keys must be present/intact.
You might also try going to website below with tractor mod/sn,see if operators manual,parts list & trans service manual avail as a free download.
https://lookup3.toro.com/request/request.cfm
