TractorLinks.com
Re: 16 hp briggs and stratton
old
10-18-2012 08:46:38
Are you 100% sure you got the cam and crank gear timed right?????? Very very common problem with small engines and I have opened up a good many that the guy got the wrong. Still remember back when I was in high school my dads boss who had a doctors degree but did not know engine got that wrong on a 5HP B/S engine Took me maybe 30 minutes to have it running
mark terrill
10-18-2012 11:46:36
 Re: 16 hp briggs and stratton in reply to old, 10-18-2012 08:46:38
that part of the motor came from factory. I'm assuming it is correct
old
10-18-2012 13:02:59
 Re: 16 hp briggs and stratton in reply to mark terrill, 10-18-2012 11:46:36
Is it an over head valve engine or a valve in block?? If it has the valves in head make sure the valves are set at the correct torque or you will have odd problems
rustyj14
10-26-2012 14:09:36
 Re: 16 hp briggs and stratton in reply to old, 10-18-2012 13:02:59
Some times-on older Briggs engines, and Tecumseh, too, the boss where the can gear fits into the block, will be sloppy, and even though you get it meshed to the correct gear, i have seen a few that would allow the cam gear to fall out of "time" with the crank-shaft when reassembling the engine. I solved one of those problems by making a loop from 1/4 inch masking tape, to hold the cam in mesh with the crankshaft, until you get it assembled.The mashed up tape doesn't seem to harm the operation.
