Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: water in crank case
[Return to Forum]
jerry 4
10-04-2012 09:50:19
74.44.225.22
i have a older riding mower witch sat out the most of its life. the engine oil is milky white,and ihave have changed it a number of times trying to clean it up.i was wondering if a little bit of isopyrple dry gas would hurt anything? and would this hurt any thing? i dont know if its condensation.
[Reply]   [No Email]
Rick54
10-04-2012 14:37:46
209.152.112.184
 Re: water in crank case in reply to jerry 4, 10-04-2012 09:50:19
sure sounds me like you leaking gas thru carb or fuel pump if equiped. check those ut and you should solve your troubles
[Reply]  [No Email]
Tom Arnold
10-04-2012 16:07:10
184.146.1.32
 Re: water in crank case in reply to Rick54, 10-04-2012 14:37:46
If that were true, then his fuel consumption should be very high and his oil level would climb higher on the dipstick. The smell of gasoline in the drained oil would be very prevalent also.
Gasoline does not make engine oil turn milky. Water does. Water can be introduced from the exterior due to the dipstick hole being left uncovered or it can come from condensation taking place inside the engine due to the crankcase not breathing properly. I suspect the latter. If the engine breather system is not functioning, then water vapour from the combustion process has no way of exiting the crankcase and it condenses on the internal parts leaving them with a whitish goo that is hard to get rid of.
[Reply]  [No Email]
jerry4
10-04-2012 10:01:45
74.44.225.22
i wanted to add this is just a beater tractor i use for firewood and the kids play on [poor mans 4wheeler]i am running HD30 oil
[Reply]  [No Email]
rrobert
10-04-2012 11:31:39
71.227.6.189
 Does it have an oil filter? in reply to jerry4, 10-04-2012 10:01:45
Two oil changes should have gotten most of the water out unless there was water in the filter. The rest of the water should evaporate with use. I will usually let them warm up a few minutes and then drain the oil.
I have heard water in oil will ruin car engine bearings.
If the case is sealed, then it is probably condensation. If the dipstick is missing, then oil would be flying out the dipstick tube.
Ford trucks are known to get a milky white slime on the oil fill cap if you only drive it a few minutes at a time.
Are you sure it isn't leaking watered down gas in the engine thru the carb or fuel pump?
[Reply]  [No Email]
dhermesc
10-04-2012 13:25:58
24.248.193.103
 Re: Does it have an oil filter? in reply to rrobert, 10-04-2012 11:31:39
That would be my guess. One oil change should have removed the water.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
