Yesterday's Tractor Co.
Shop Now View Cart
Re: needing print out of BS 19? engine
joe csuti
10-02-2012 11:28:56
Goto link below,after you download put mouse pointer over pic/text,same will change to a magnifying glass with a + in center,click left mouse button to enlarge,if your browser doesn't support this feature,try a different browser.The link below is for ign system with coil OVER flywheel & key tab on face of flywheel,IF maga-matic system under flywheel then flywheel timing isn't an issue,there may/may not be a key tab on flywheel on this system,briggs manual only shows how to remove flywheel & makes no mention or shows key tab,flywheel & crank may just be a taper lock held with flywheel nut,I had a mod 23 yrs ago with magna-matic system but never had a problem with same or need to pull flywheel cover,so I don't know for sure if there's a key tab to lock flywheel.
