Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: needing print out of BS 19? engine
joe csuti
10-02-2012 03:52:13
What style ign system on eng?The mod#19 eng used 2 different systems depending on age of eng.
One system had coil mounted OVER flywheel & used a tab on face of flywheel to set flywheel timing,other system was the magna-matic with a rotor mounted on crank & coil UNDER flywheel,on this system the magnet rotor is clamped to crank & keyed to shaft with a woodruff key,ign timing is set by moving plate with coil on it & matching set mark to eng mod# on rotor,the flywheel is held by crank/flywheel taper & flywheel nut and has no effect on ign timing,if you have this system check crank very carefully,woodruff key may be sheared flush with shaft.
Farmallb
10-02-2012 10:52:47
 Re: needing print out of BS 19? engine in reply to joe csuti, 10-02-2012 03:52:13
Joe, How ya doin? Say, would you please send me the print out you did before. Its the B&S on a Simplicity walk behind garden tractor with the tapered shaft with no key way. Thanks ALOT.
Copyright © 1997-2015 Yesterday's Tractor Co.
