Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Briggs 16hp vanguard v-twin starter
joe csuti
09-29-2012 16:51:30
Briggs sells a special universal socket pn 19353 for starter removal but same pricey,try useing a 13mm 12pt 1/4" drive socket & a univ joint,if too big to fit in try a 1/4" wobble extention.Briggs used two different drive assemblies with nylon gears on vanguard eng,both are designed to be used on flywheel with an aluminum ring gear,do not use a drive with a steel gear,these are designed for a flywheel with a steel ring gear.
t.r.k.
09-30-2012 12:17:30
 Re: Briggs 16hp vanguard v-twin starter in reply to joe csuti, 09-29-2012 16:51:30
Just want to add that the metal gear has 1 less tooth than the plastic gear does.
If your starter is having trouble pushing the engine over compression, The engine probably needs a valve adjustment.
A lot of those starter bolts have a Torx socket in the head. I usually can get them with a 1/2" 1/4 drive socket,it goes by the flat in the starter drive onto the bolt at an angle, but usually works.
