| Garden Tractors Discussion Forum |
Topic: Briggs 16hp vanguard v-twin starter
[Return to Forum]
| Author |
[Modern View]
| mightymolinekid
09-29-2012 12:50:15
24.183.138.199
Hey all, I have a Bolens 1669 with a 16hp Briggs and Stratton Vanguard v-twin. The junk plastic starter drive gear went, as I'm sure is common with these. Is there some national secret to getting the top starter bolt out? I'm guessing it takes some kind of special tool...is there an upgrade to the plastic gear or is it designed to be the sacrificial part, instead of the flywheel ring gear. Any help appreciated! |
| mightymolinekid
10-01-2012 10:11:39
166.181.3.114
Re: Briggs 16hp vanguard v-twin starter in reply to mightymolinekid, 09-29-2012 12:50:15
| Thanks for the help everyone! Can just the gear be replaced?? |
| chuck in IN.
10-01-2012 17:17:04
184.18.254.204
Re: Briggs 16hp vanguard v-twin starter in reply to mightymolinekid, 10-01-2012 10:11:39
| Yes you can replace just the gear.I sell them for $3 each plus shipping they list for around $6 at most shops |
| Stephane lacasse
01-27-2013 06:48:42
184.145.3.139
Re: Briggs 16hp vanguard v-twin starter in reply to chuck in IN., 10-01-2012 17:17:04
| do you still have the 16hp Briggs and stratton vtwin starter plastic gear for sale? |
| d beatty
10-01-2012 10:05:45
24.12.128.253
| Have you ever thought of looking on Ebay there are a lot of Briggs and stratton starters on there. If you buy a new one they start out around $ 80.00 on up. |
| carogator
09-30-2012 17:35:09
64.12.116.79
| Definitely try valve adjustment first!! You also have to KNOW the proper procedure as it does not set on TDC. Piston has to drop 1/4" past TDC. It has to set on compression relief cam. |
| carogator
10-01-2012 17:38:43
205.188.117.17
Re: Briggs 16hp vanguard v-twin starter in reply to carogator, 09-30-2012 17:35:09
| joe csuti
09-29-2012 16:51:30
151.198.124.204
| Briggs sells a special universal socket pn 19353 for starter removal but same pricey,try useing a 13mm 12pt 1/4" drive socket & a univ joint,if too big to fit in try a 1/4" wobble extention.Briggs used two different drive assemblies with nylon gears on vanguard eng,both are designed to be used on flywheel with an aluminum ring gear,do not use a drive with a steel gear,these are designed for a flywheel with a steel ring gear. |
| t.r.k.
09-30-2012 12:17:30
71.31.64.233
Re: Briggs 16hp vanguard v-twin starter in reply to joe csuti, 09-29-2012 16:51:30
| | Just want to add that the metal gear has 1 less tooth than the plastic gear does. If your starter is having trouble pushing the engine over compression, The engine probably needs a valve adjustment. A lot of those starter bolts have a Torx socket in the head. I usually can get them with a 1/2" 1/4 drive socket,it goes by the flat in the starter drive onto the bolt at an angle, but usually works. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
