Took some imagination but got a Kohler 320 bolted to it.
It is hydrostatic and has a lift for the snow blade and they work off the same pump. The transmission doesn't whine. The lift does. When there is snow stick to the blade, the cylinder can't lift it. Also, the lift whines a lot.
What is the correct oil and filter for the hydraulic system for this tractor? How do I drain most of it out?
thanks.
thanks.
