allis chalmers 312
Anonymous-0
allis chalmers 132 clutch wont disengage you can start it in gear but cant shift out of neutral after running without grinding gears if it matters it has a tiller mounted on it and a hydro lift
I have a Simplicity 7112 which may be similar to your Allis Chalmers - not sure. On my tractor, there is a small brake pad on one of the levers that stops the pullies when the clutch is pushed in. Replacing this brake pad on mine got rid of the grinding - that and installing the belt guard.
