Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 76 Cadet and others with keyed rear rims
rustyj14
09-24-2012 20:32:22
I have seen, on the internet, a rear wheel puller made by somebody who fixes the tires on those back wheels. To wit: They made two inch thick steel bars to fit across the back of the rim with enough sticking out to have holes drilled in the ends of the steel bars., then they made a steel plate, with an adjustable screw/bolt in the center of it. They welded bars onto the steel plate, then used the plate on the outside of the wheel. Those bars are drilled, too, to accept the large, long steel bolts that hold the whole mess together. In the center of the plate , they drilled a hole, and welded a nut to fit the center bolt in the plate, and that bolt is tightened against the axle stub that sticks out of the wheel. A caution about hammering on the end of the axle!!! It will swell up, and you will never get the wheel off the axle. BT/DT! The inventors say to tighten the center bolt very tight, then apply PB Blaster liberally, and let it sit overnight. I'd also apply heat to the wheel hub. I'd try building that puller, but i'm not going to be doing this stuff for veey much longer. And anything that comes in now had better not need the rear wheels pulled off! RJ PS. I can't remember where i saw that puller. I did make a drawing of it from memory. It was in one of the lawn tractor sites, about 6 months ago. Maybe somebody here can tell you where to look. Rusty J.
