Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Replacing PTO clutch bearing
[Return to Forum]
Bob - MI
09-22-2012 07:19:10
75.129.96.109
I just had the bearing fail in my Cub Cadet 2518 PTO clutch. It started to give that dry bearing howl and then stopped disengaging. This machine has 200 run hours on it and is my go-to for lawn mowing as well as the snowthrower for my 1/4 mile long Michigan driveway.
While reading many posts on multiple sites there seemed to be a theme that says that these can't be repaired. I checked the pricing for a replacement and the OEM Cub price is $500+. Aftermarket about $220.00. In all I figured the worst I could do is fail replacing the bearing and I would have to buy a new clutch.
So... in less than 10 minutes I had the mounting bolt off and managed to dis-assemble the front pully from the rest of the clutch. The bearing was frozen solid in front but free in the rear.
Took the pully to the shop and we pressed the old bearing out. This is an NSK bearing with the number clearly etched on the inner race. Local bearing supply shop had it in stock at $23.00. NSK by the way was suggested to be one of the best quality available but a Chinese copy was less than 1/2 price. No thanks.
We measured the press fit difference between the pully and the bearing and it was .002". Calculating the expansion rate of steel @ 0.0000073 per degree F per inch we heated the pulley to 300 degrees and we easily pressed the bearing into place.
Back home, re-assembly was 10 minutes and it works like new.
I am lucky to have a machine shop at my disposal but this job could be done by anyone with good mechanical skills and a large vise. An understanding wife that will let you heat the pulley in the oven will help as well.
[Reply]   [No Email]
AzPeapicker
09-22-2012 13:33:03
70.176.21.242
 Re: Replacing PTO clutch bearing in reply to Bob - MI, 09-22-2012 07:19:10
Bob
I have also drilled out the spot welds on idler pulleys & replaced the bearing . Then drilled 1/4 " inch holes where the spot welds were & bolted the two halves together . They work just as good as a new one .
John
[Reply]  [No Email]
oldtanker
09-22-2012 13:56:22
66.228.255.239
 Re: Replacing PTO clutch bearing in reply to AzPeapicker, 09-22-2012 13:33:03
Been there done that......worked good for me too.
Rick
[Reply]  [No Email]
ray hofstetter
09-22-2012 12:58:23
166.137.88.38
Usually anyone with mechanical skills, determination, and a parts source can repair "non-repairable" stuff. It's all the other people that make the dealers parts people rich....
[Reply]  [No Email]
AzPeapicker
09-22-2012 09:28:23
70.176.21.242
Bob
I say AMEN to having a understanding Wife , normally they don t want the men in the kitchen.
I have worked on Carbs in the house but she wll only ket if it gets to cold to work outside.
I don t know about using her oven .
John
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
