| Garden Tractors Discussion Forum |
Topic: John Deere 240 turns over hard and will not start
[Return to Forum]
| Author |
[Modern View]
| Jack in Michigan
09-19-2012 04:34:42
76.249.8.14
I am helping a person with their John Deere 240 Garden Tractor. It has the 14 hp Kawasaki engine. It turns over very hard and will not start. The battery checks out ok, but it needs to be jumped for it to turn over at all. The owners had it in shop a few years back and were told it was out of timing, and I am not sure what that means. I am not familiar with these engines at all, so I need to seek some advise. Thanks for any help. Jack |
| David G
09-20-2012 07:23:33
205.215.206.18
Re: John Deere 240 turns over hard and will not start in reply to Jack in Michigan, 09-19-2012 04:34:42
| | El Toro is correct, the only way to get out of time is to have a key sheared. You can check to see if it is a timing issue by cranking with the spark plug wires unhooked. If it cranks the same, it is not a timing issue. I would suspect you have a cable or connection issue somewhere, feel for a warm connection while cranking. |
| MCOHIO
09-19-2012 08:32:38
71.72.158.81
| Try to confirm if it will start with starting fluid sprayed into the carburetor while you are cranking the engine. If it runs on the starting fluid then the problem is in the carburetor and not getting gasoline into the engine. If still it does not run pull one of the plugs, reattach the plug wire and ground the body of the plug to the engine and check for spark while you are cranking. DO NOT hold the plug in your hand. My last resort would be to tear down an engine. These engines are timed by gears and to get one to jump timing would require a rebuild to fix it. |
| joe csuti
09-19-2012 05:36:05
70.111.202.211
| Check valve clearance settings,same may be excessive & acr not working,you may need service manual for specs or someone may reply with specs,also check with local jd dealer for settings. |
| El Toro
09-19-2012 05:02:27
108.3.143.30
| If it's out of time the cam gear or the crankshaft gear has probably sheared a woodruff key. The engine would have to be torn down to find the problem. It may cost more to fix the engine than it's worth. You may be able to get a short block, but they're not cheap. Hal |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
