carb cleaning
Anonymous-0
i have a genarator with a wisconsin robin engine on it. has set for about a year,i clean the carb to the best of my ability ,remove the bowl ,float and needle vavle.fresh gas. it will only run on half choke.do you think it woult hurt to run about aquart of gas to one bottle of carb cleaner though it?
You need 3 thing when you clean a carb. #1 spray carb cleaner. #2 compressed air to blow out all the passage ways and #3 a small wire so as to poke out all the passage ways and jets so you know there open. Only running when choked says the main jet is clogged
PS.i dont really want to remove the carb from the motor because of the complicated govenor / thottle set up. i geuss i souldhave used stabil
Your only options are to remove and clean or remove and replace, if you want it to run.
A sketch or a picture of the linkage is a good idea. I usually mark the holes in the arms with a scriber so I know which hole the springs, links, etc. use.
