TractorLinks.com
Re: BS engine on Simplicity V walk behind tractor
cwtech
09-14-2012 07:23:06
I'm thinking it may be the old model 19 (not 19D) with the Magnematic ignition system.
The magneto coil is under the flywheel, points & condenser are external on the side of the crankcase.
The arrow on the left leg of the armature is aligned with the engine model marked on the rotor (which is clamped onto the crankshaft.
When the two marks are aligned, the flywheel is installed with the starter pin (on the face of the flywheel) at the 10:30 o'clock position.
joe csuti
09-14-2012 13:59:53
 Re: BS engine on Simplicity V walk behind tractor in reply to cwtech, 09-14-2012 07:23:06
The ign could be either type,at one time I had two mod 19 eng,one had standard over the flywheel coil,other had magna-matic,due to fact he said crank smooth & he had 3 holes in flywheel & stud(roll pin)I would more suspect eng has over the flywheel coil as he's not giving out much info on ign system also magna-matic crank has a notch in it for a woodruff key to lock magnet rotor to crank.
