| Garden Tractors Discussion Forum |
Topic: BS engine on Simplicity V walk behind tractor
[Return to Forum]
| Author |
[Modern View]
| Farmallb
09-13-2012 08:13:19
67.142.178.20
It has numbers 79? 706029 597966Im needing to know how the flywheel goes back on. It isnt keyed on the shaft or the pulley. There both smooth, both on the shaft and on the bore. Its an 40s engine Im thinking. |
| joe csuti
09-13-2012 13:25:02
151.198.124.164
Re: BS engine on Simplicity V walk behind tractor in reply to Farmallb, 09-13-2012 08:13:19
| | Is the mod# of eng(1st two numbers)79 or possibly 19? On the old briggs number series eng,on the mod 19 & 23 eng the flywheel key is a tab that bolts to face of flywheel to lock flywheel due to fact that flywheel timing is adjustable on these eng |
| cwtech
09-14-2012 07:23:06
71.251.37.24
Re: BS engine on Simplicity V walk behind tractor in reply to joe csuti, 09-13-2012 13:25:02
| | I'm thinking it may be the old model 19 (not 19D) with the Magnematic ignition system. The magneto coil is under the flywheel, points & condenser are external on the side of the crankcase. The arrow on the left leg of the armature is aligned with the engine model marked on the rotor (which is clamped onto the crankshaft. When the two marks are aligned, the flywheel is installed with the starter pin (on the face of the flywheel) at the 10:30 o'clock position. |
| joe csuti
09-14-2012 13:59:53
70.111.202.86
Re: BS engine on Simplicity V walk behind tractor in reply to cwtech, 09-14-2012 07:23:06
| The ign could be either type,at one time I had two mod 19 eng,one had standard over the flywheel coil,other had magna-matic,due to fact he said crank smooth & he had 3 holes in flywheel & stud(roll pin)I would more suspect eng has over the flywheel coil as he's not giving out much info on ign system also magna-matic crank has a notch in it for a woodruff key to lock magnet rotor to crank. |
| joe csuti
09-13-2012 16:03:27
151.198.124.204
| Goto link below & look at pic of flywheel,if it's the same as your's follow instructions in text to set points/flywheel timing. |
| Farmallb
09-13-2012 16:43:39
67.142.178.20
Re: BS engine on Simplicity V walk behind tractor in reply to joe csuti, 09-13-2012 16:03:27
| also, it was too small a print and blury besides so I couldnt read it, just saw the pics. Thanks again. |
| joe csuti
09-13-2012 18:01:13
151.198.123.252
Re: BS engine on Simplicity V walk behind tractor in reply to Farmallb, 09-13-2012 16:43:39
| After you goto link & download pic,move mouse pointer over pic/text,pointer will change to a magnifing glass with a + in center,click left mouse button,this will enlarge pic/text. |
| Farmallb
09-13-2012 16:42:30
67.142.178.20
| Thanks Joe. I dont havr that tab. Ive got one stud and 3 holes on the outside of the flywheel face. Nothing on the stud. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
