JD210 clutch
hippie1st
Have a friend at work, with a JD210. Said he jammed on clutch pedal to avoid some brush. Not pedal will not return. He does not have a manual,and I have not not seen the machine yet.<br Any help would be great. I can also be found on the 8N board.
Thanks Hippie
weekendfreedommachinesDOTcom is your best reference.
The parking brake is pretty easy to get jammed on those. Problem is, there are three different parking brake setups on the 200-series.
Try this: while lifting up on the black knob farthest to the right on the lower part of the console facing the seat, push down hard on the left brake/clutch pedal. That should work for some tractors. If that doesn't do it, hold up on that knob while pushing down hard on the right brake-only pedal.
If that doesn't do it, something is broken or bent underneath.
