Re: 16.5 HP Briggs Stratton
Bill Copeland
09-12-2012 07:30:17
I have good gas supply. When I shove the throttle lever up there is no hesitation or loss of power but the motor will race when you shut off the deck or travel on level ground. I should be able to run this motor at half throttle and have the govenor kick in when i go up a hill but it won't. The steeper the hill the slower the motor runs.
09-13-2012 19:31:06
 Re: 16.5 HP Briggs Stratton in reply to Bill Copeland, 09-12-2012 07:30:17
Well, if it overspeeds when you take the load off, the governor is not doing its job. Like Old suggested, check the external linkage. if its o.k., not binding, and adjusted properly. (you should find the procedure online somewhere.) Then its probably a problem with the flyweight assembly inside the case.
