Briggs condensor
S/C BOB
I m needing to replace the condensor on my wood splitter it s has an older briggs horizontal engine. The # on the part is 290927 but I m having trouble finding one on the web. I d appreciate any advice. Thank you
Call jackssmallengines at 1-877-737-2787. You will need the engine model and spec numbers off the fan shroud. Hal
Any more I do away with the points and condenser on these old B/S engines and either install a $10 aftermarket ignition chip or buy a newer B/S electronic ignition type coil and never look back. I have an old Murry garden tractor that I did the chip on and it sits for 2 or 3 years and when I want I pour in gas and jump it and it starts right up
