Help carb. float Kohler K301
SPT
Gas is running thru carb., have taken bowl off and held up float and gas is shutting off, put bowl on and gas runs thru carb. Have adjusted float at different levels with no good results. Can shake carb. and hear float rattling, but when I turn on gas it runs right thru it like float is not floating. Checked float in water, it floats, no holes.
Any suggestions?
The most probable cause is dirt in float needle seat or gasket under float needle seat leaking or cracked,other possible causes,float needle/needle seat worn,float out of level,to check any of the above carb must be removed from eng.If a worn/damaged float needle seat or gasket on seat leaking causeing the problem kohler manual says replace the carb as needle seat is not serviceable,also pushing float up with finger is not always an accurate test as finger can put more pressure on float than gas in bowl.Try replaceing float needle 1st to see if that cures problem along with setting float to correct level.
Slight oversight on my part reading manual,if carb has brass float & is a kohler carb with hi/low speed needles float seat assembly is replaceable,new needle/seat included in rebuild kit,if carb a walbro with fixed/adjustable jets & plastic float,float needle seat not serviceable,sorry for the confusion.
I doubt the vent can become clogged on this carb but if it is, then these are the symptoms.
When float is removed, shake it. If it has liquid sloshing around in it, it needs to be replaced.
I have replaced needle valve and seat, adjusted float to specs., tried a different float that works in another engine, if I take carb, off and turn it sideways it will not leak, but when I hold it upright, gas runs right thru it. Has me puzzled, am sure it is something very simple, but can't see the forest for the trees.
Thanks for the suggestions, I will figure it out.
