Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: Help carb. float Kohler K301
[Show Entire Topic]  [Return to Forum]
joe csuti
09-02-2012 17:22:57
151.198.127.184
The most probable cause is dirt in float needle seat or gasket under float needle seat leaking or cracked,other possible causes,float needle/needle seat worn,float out of level,to check any of the above carb must be removed from eng.If a worn/damaged float needle seat or gasket on seat leaking causeing the problem kohler manual says replace the carb as needle seat is not serviceable,also pushing float up with finger is not always an accurate test as finger can put more pressure on float than gas in bowl.Try replaceing float needle 1st to see if that cures problem along with setting float to correct level.
[Reply]   [No Email]
joe csuti
09-02-2012 17:37:22
151.198.127.184
 Re: Help carb. float Kohler K301 in reply to joe csuti, 09-02-2012 17:22:57
Slight oversight on my part reading manual,if carb has brass float & is a kohler carb with hi/low speed needles float seat assembly is replaceable,new needle/seat included in rebuild kit,if carb a walbro with fixed/adjustable jets & plastic float,float needle seat not serviceable,sorry for the confusion.
[Reply]  [No Email]
SPT
09-03-2012 13:08:44
75.205.77.196
 Re: Help carb. float Kohler K301 in reply to joe csuti, 09-02-2012 17:37:22
I have replaced needle valve and seat, adjusted float to specs., tried a different float that works in another engine, if I take carb, off and turn it sideways it will not leak, but when I hold it upright, gas runs right thru it. Has me puzzled, am sure it is something very simple, but can't see the forest for the trees.
Thanks for the suggestions, I will figure it out.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
