Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 2554 Scotts Garden Tractor Kohler 25HP Flywheel
joe csuti
09-01-2012 18:02:43
If eng a CV25,air gap is .008"-.012"(.010" nominal)
joe csuti
09-02-2012 18:14:45
 Re: 2554 Scotts Garden Tractor Kohler 25HP Flywheel in reply to joe csuti, 09-01-2012 18:02:43
If eng a cv725 the coil air gap is .011"-.013"
Before you epoxy magnet back in confirm magnet north pole faceing same direction as north pole on other magnets,otherwise you'll be bucking other magnets & this will affect alt output/operation.You can check magnet polarity & other magnets polarity position with a pocket compass.
bigmackerel11
09-03-2012 10:12:39
 Re: 2554 Scotts Garden Tractor Kohler 25HP Flywheel in reply to joe csuti, 09-02-2012 18:14:45
Joe, thanks for great info.
bigmackerel11
09-01-2012 22:53:10
Joe Csuti: Engine is CV725S. I removed flywheel,and found lower part of punch inside (Was 1/4" Dia by 1" long !!). Found one of 6 curved magnets was not glued to inside of flywheel (Magnet was not damaged, just stucked to little coils around a lot of coils around crankchaft). I think I broke seal/glue when turning flywheel while using puller. Can this magnet be glued back on, or do I buy a new flywheel? All of you have been a great help. Again, this is a great Forum. Thanks from San Diego Ca. Hour meter shows over 1100 hours, used on 5 acres, and still going strong.
Copyright © 1997-2015 Yesterday's Tractor Co.
