| Garden Tractors Discussion Forum |
Topic: 18 hp briggs
[Return to Forum]
| Author |
[Modern View]
| bill mart
09-01-2012 16:58:28
69.204.65.189
Working on a 1992 Craftsman rider with a Briggs twin cylinder 18 hp verticle shaft engine. Seems to have a knock to it, maybe in the upper half. Are these engines known to go bad? The reason I ask is the deceased owner had an extra 18 hp engine laying in pieces behind the shed the mower was in. Bill |
[Reply] [No Email] | |
| Bill Hazelbakerxads
09-04-2012 06:19:34
50.73.114.130
Re: 18 hp briggs in reply to bill mart, 09-01-2012 16:58:28
| Replaced mine 2 times before we found out it was carbon build up on top of pistons. Went to straight 30 weight oil and no problem for several years now |
| d beatty
09-02-2012 21:49:30
24.12.128.253
| I have a Briggs 18 HP opposed two cylinder.If I let it set over winter it wants to knock for a while but comes out of it. If I start it ever several weeks it wont knock. I can now let it set over winter sinse I use Lucas oil treatment. If it sets for a long time oil drain away from top bearing. |
| wisbaker
09-02-2012 20:36:04
184.157.223.164
| Some of that newer B&S stuff says "use synthetic oil only" I hear if you don't you get valve problems. |
| jt
09-02-2012 20:48:24
166.137.88.35
Re: 18 hp briggs in reply to wisbaker, 09-02-2012 20:36:04
| I am a Briggs Master Tech and have not seen Briggs telling you to use synthetic oil. As for valve problem issye in newer OHV Briggs engines, if you use gas that gets a little old and stale, it will cause valve stems to get deposits on them, stick in guides, and push guides out of heads and bend push rods. |
| rrobert
09-02-2012 11:25:40
71.227.6.189
Pull sparkplugs in reply to bill mart, 09-01-2012 16:58:28
| | And check for compression. I had an 18 hp that the valves would stick when it got warm. I had a 16 Hp Vortec that ran but seemed flat like the governor was missing. It ended up being that one connecting rod was broken. |
| jt
09-02-2012 07:31:42
166.137.88.18
| The biggest "common" issue with these engines were valves. Seats falling out and guides getting loose. A knock can also have carbon buildup in head and piston hitting it. Easiest thing to do is pull heads and take a peek at top end of engine. You can check seats, guides and cylinder for wear or piston slap. |
| bill mart
09-02-2012 18:55:24
69.204.65.189
Re: 18 hp briggs in reply to jt, 09-02-2012 07:31:42
| thanks to all,will probably pull the heads,will check compression before and after. Bill |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
