Yesterday's Tractor Co.
Shop Now View Cart
Re: 2554 Scotts Garden Tractor Kohler 25HP Flywheel
08-30-2012 20:50:12
I don"t understand why you would hold the flywheel to remove the clutch, BUT, if your punch tip is only in the 1/4 inch range then go ahead and run it. Any bigger than that and you need to remove the flywheel.
08-30-2012 21:23:57
 Re: 2554 Scotts Garden Tractor Kohler 25HP Flywheel in reply to mrjdman80, 08-30-2012 20:50:12
Thanks for the fast reply. Sorry about the 2 extra posts. I had to use punches to keep the flywheel from turning, while removing the PTO chutch. I hope this makes sense. The broken punch is a Craftsman 7/32. The broken end of the punch is about 3/8". The other end, under the flywheel might taper to 1/4" Dia and 1" long? Where is a good place to buy a flywheel puller? Thanks again for the help.
