TractorLinks.com
Re: Bolens 1476 starting issues
dinosaur
08-28-2012 06:00:24
It does look like the choke is closing all the way, but still won't start on it's own. BUT if I hold my hand over the carb, it will start. There is very good suction.
Also when it does start this way (hand over carb) when I remove my hand, and it's been running for a few minutes, there is gas dripping from the intake of the carb, but not when I use the fluid.
Does this sound like a carb adjustment is needed?
Thanks for all your suggestions
El Toro
08-29-2012 04:03:29
 Re: Bolens 1476 starting issues in reply to dinosaur, 08-28-2012 06:00:24
Is there a solenoid on the carburetor that's used to shutoff the fuel? If there is it may not be opening allowing fuel into the carburetor.
Is a fuel pump used? Before fuel injection we used our hand over the throat of the carb just to checked out the fuel pump. If it started using your hand it was usually the pump. Hal
PS: Check the fuel flow from the tank to the carb. See if there's a full stream of gas. Hold a clean container to catch the gas.
