| Garden Tractors Discussion Forum |
Topic: Bolens 1476 starting issues
[Return to Forum]
| Author |
[Modern View]
| dinosaur
08-24-2012 07:24:00
216.164.3.26
It has the S14D engine and everytime I need to start the tractor, I have to squirt starting fluid in it to start. Once started it runs fine, and even when it"s hot I have to use starting fluid. I have replaced the fuel pump, filter and shutoff valve in case of any restrictions. Any thoughts? |
| cwtech
08-24-2012 08:18:13
71.251.36.190
Re: Bolens 1476 starting issues in reply to dinosaur, 08-24-2012 07:24:00
| El Toro
08-24-2012 08:10:23
108.3.143.30
| If that's a gas engine you need to make sure the choke is closing fully. I would install a primer bulb to squirt that atomized gas directly into the air stream. Hold your hand over the throat of the carburetor and see if there's good suction on your hand. Good suction means good intake manifold vacuum. If there's little suction could mean a vacuum leak or your rings may have worn the cylinder walls. Hal |
| dinosaur
08-28-2012 06:00:24
216.164.3.26
Re: Bolens 1476 starting issues in reply to El Toro, 08-24-2012 08:10:23
| It does look like the choke is closing all the way, but still won't start on it's own. BUT if I hold my hand over the carb, it will start. There is very good suction. Also when it does start this way (hand over carb) when I remove my hand, and it's been running for a few minutes, there is gas dripping from the intake of the carb, but not when I use the fluid. Does this sound like a carb adjustment is needed? Thanks for all your suggestions |
| El Toro
08-29-2012 04:03:29
108.3.143.30
Re: Bolens 1476 starting issues in reply to dinosaur, 08-28-2012 06:00:24
| Is there a solenoid on the carburetor that's used to shutoff the fuel? If there is it may not be opening allowing fuel into the carburetor. Is a fuel pump used? Before fuel injection we used our hand over the throat of the carb just to checked out the fuel pump. If it started using your hand it was usually the pump. Hal PS: Check the fuel flow from the tank to the carb. See if there's a full stream of gas. Hold a clean container to catch the gas. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
