TractorLinks.com
Re: Unplug the connection
sflem849
08-21-2012 09:45:40
That is what I thought at first, but when you flip the switch you can see and here the clutch engage.
rrobert
08-21-2012 12:10:48
 odd in reply to sflem849, 08-21-2012 09:45:40
Can you check the center bearing/bushing?
If the switch is off, you should be able to spin the blades but the crankshaft should not rotate. The pulley on the pto clutch should rotate without the crankshaft rotating. Could be the bearing is froze or the bushing is worn out.
sflem849
08-22-2012 12:06:56
 Re: odd in reply to rrobert, 08-21-2012 12:10:48
That looks like the winner. I pulled the clutch this morning and the lower bearing is froze up. I bought only the lower one because the top one looked like a pain to fix and the clutch came off really easy.
