Jack in Michigan
My friend is having a problem with his glow plug indicator light staying on for an extended period of time. The ignition switch is newer from a previous problem. Now even though the light stays on the voltage to the glow plugs drops out after one minute. I was told by another source that it should drop out after 30 seconds or less depending on the outside temperature. He is afraid of the damage this could cause to the engine if there is something else is going on. The glowplug controller / relay is new. The glowplugs are the original ones and have never been changed. Any help would be appreciated. Thanks, Jack
