Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Clean carb
Poppa Collins
08-12-2012 04:19:03
Thanks. We've tried all the things you mentioned. May have to get a kit and tear carb totally apart. It was much simpler when you could turn a screw. I'm assuming the shut off switch either works or not. It has power. Could it be partially closed?
rrobert
08-12-2012 04:27:40
 It could be faulty in reply to Poppa Collins, 08-12-2012 04:19:03
If you can hear a clicking sound, then it should be working.
Easiest way to check it is to remove it, hold it against the frame away from gas and turn the key. You should be able to see the plunger go up and down.
When you remove the shut-off solenoid, gas should drain from the bowl. If not, then gas is not getting to the bowl. If gas does drain from bowl, then a jet inside is clogged.
I am not sure how your fuel pump is set up. Check the vaccuum line for the fuel pump and make sure it isn't cracked.
A bad or incorrectly gapped sparkplug could also cause issues.
