| Garden Tractors Discussion Forum |
Topic: Clean carb
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| rrobert
08-11-2012 12:35:25
71.227.6.189
There should be a shut off solenoid holding the bowl on the engine. Make sure that has power to it when the key is on. Make sure it is clicking when you turn the key to "on".First, make sure the fuel pump it pumping fuel, if applicable. Make sure the gas isn't water. Next, would be to clean out the carb. Make sure the needle and seat are moving properly. I would take the needle out and blow air backwards thru the seat. Sometimes crap gets stuck there. Do not blow air thru the fuel pump if it has one. I had a Kawasaki do this. It corrected itself and I never found the problem. |
[Reply] [No Email] | |
| Poppa Collins
08-12-2012 04:19:03
108.39.166.112
Re: Clean carb in reply to rrobert, 08-11-2012 12:35:25
| Thanks. We've tried all the things you mentioned. May have to get a kit and tear carb totally apart. It was much simpler when you could turn a screw. I'm assuming the shut off switch either works or not. It has power. Could it be partially closed? |
| rrobert
08-12-2012 04:27:40
71.227.6.189
It could be faulty in reply to Poppa Collins, 08-12-2012 04:19:03
| | If you can hear a clicking sound, then it should be working. Easiest way to check it is to remove it, hold it against the frame away from gas and turn the key. You should be able to see the plunger go up and down. When you remove the shut-off solenoid, gas should drain from the bowl. If not, then gas is not getting to the bowl. If gas does drain from bowl, then a jet inside is clogged. I am not sure how your fuel pump is set up. Check the vaccuum line for the fuel pump and make sure it isn't cracked.
A bad or incorrectly gapped sparkplug could also cause issues. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
