TractorLinks.com
Re: Cub 2072 Hydro
Mike Westerlund
08-09-2012 04:50:52
Thanks much for the response. Any suggestions on how to get shims and valve out of hole? Magnet maybe? The plug and spring look ok but I obviously want to pull valve/shims and inspect seat, etc. Am I correct in theory that if plug does not seat correctly, pressure will not build and bypass causes drop in pressure? So more shims; more pressure? Also, could a bad implement relief (600#) cause the same failure. Again thanks. This machine has come such a long way. If this gets solved its a keeper for sure. Mike
ANON
08-09-2012 07:19:02
 Re: Cub 2072 Hydro in reply to Mike Westerlund, 08-09-2012 04:50:52
Small magnet should work. Spring can be deceiving. Can put small flat washers between cap and spring. Spring may have been swapped for the lift side spring by mistake. I think you can tell by the coil count. Would help to put a pressure gauge--don't recall pressure limits.
Mike Westerlund
08-13-2012 05:04:03
 Re: Cub 2072 Hydro in reply to ANON, 08-09-2012 07:19:02
Thanks for all the feedback for the "new guy". Good news is all the feedback supports what i have done to date. Next step is to get new relief spring, shim if required and try to build some pressure (which is obviously lacking). Anyone have a good method to clean/clear the valve seat for the valve cone going in from the side? I plan on making sure the cone is seating when i put new spring in. While all looks clean and OK with valve I can not be sure it is tight into housing and able to build pressure. If this works I will post results for others to benefit from. Thanks, Mike
Mike Westerlund
08-17-2012 07:04:10
 Re: Cub 2072 Hydro in reply to Mike Westerlund, 08-13-2012 05:04:03
New relief spring and cone did not fix the issue. Have not put a gauge on test port to see whats happening but problem still persists. Warms up, hydro gets weak, power steering gets hard, hydro lever has resistance and cant push forward..level ground operates OK but never to what cold start was for power. Never stops moving and can cut for hours with limited uphill work. Could check valves be causing this? What do the two checks do and how can I tell if these are bad? as always thanks for feedback.
