| Garden Tractors Discussion Forum |
Topic: Re: Cub 2072 Hydro
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| ANON
08-08-2012 20:37:23
69.248.113.235
Check the relief valve on the side of the hydro unit--make sure it is free and the spring is correct. |
[Reply] [No Email] | |
| Mike Westerlund
08-16-2012 19:13:35
75.192.126.213
Re: Cub 2072 Hydro in reply to ANON, 08-08-2012 20:37:23
| Relief spring and cone replaced and still a problem. Could the check valves cause the problem? What do they do and how can I trouble shoot. Everything is fine until warm up. Just seems odd the power steering would suffer as well. Any thought appreciated. |
| Mike Westerlund
08-09-2012 05:57:56
75.192.79.233
| And yet another update. Pulled the valve cone (looks good); no shim pack was in hole so eithor; a.someone else been here before in attempt to get pressure right. b.it did not need it to get pressure due to spring size. c.it was not put in when built and/or after a service. Any thoughts? Does this relief require shims? I have not tested pressure or spring specs. it seems this is a step I need to take but will now need to get guage. Again thanks for any insight. |
| Mike Westerlund
08-09-2012 04:50:52
75.192.79.233
| Thanks much for the response. Any suggestions on how to get shims and valve out of hole? Magnet maybe? The plug and spring look ok but I obviously want to pull valve/shims and inspect seat, etc. Am I correct in theory that if plug does not seat correctly, pressure will not build and bypass causes drop in pressure? So more shims; more pressure? Also, could a bad implement relief (600#) cause the same failure. Again thanks. This machine has come such a long way. If this gets solved its a keeper for sure. Mike |
| ANON
08-09-2012 07:19:02
69.248.113.235
Re: Cub 2072 Hydro in reply to Mike Westerlund, 08-09-2012 04:50:52
| Small magnet should work. Spring can be deceiving. Can put small flat washers between cap and spring. Spring may have been swapped for the lift side spring by mistake. I think you can tell by the coil count. Would help to put a pressure gauge--don't recall pressure limits. |
| Mike Westerlund
08-13-2012 05:04:03
75.197.211.113
Re: Cub 2072 Hydro in reply to ANON, 08-09-2012 07:19:02
| Thanks for all the feedback for the "new guy". Good news is all the feedback supports what i have done to date. Next step is to get new relief spring, shim if required and try to build some pressure (which is obviously lacking). Anyone have a good method to clean/clear the valve seat for the valve cone going in from the side? I plan on making sure the cone is seating when i put new spring in. While all looks clean and OK with valve I can not be sure it is tight into housing and able to build pressure. If this works I will post results for others to benefit from. Thanks, Mike |
| Mike Westerlund
08-17-2012 07:04:10
75.197.37.89
Re: Cub 2072 Hydro in reply to Mike Westerlund, 08-13-2012 05:04:03
| New relief spring and cone did not fix the issue. Have not put a gauge on test port to see whats happening but problem still persists. Warms up, hydro gets weak, power steering gets hard, hydro lever has resistance and cant push forward..level ground operates OK but never to what cold start was for power. Never stops moving and can cut for hours with limited uphill work. Could check valves be causing this? What do the two checks do and how can I tell if these are bad? as always thanks for feedback. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
